gllong21620
Jun 11, 2021Tutor
CM1000 losing connection with R7000
Hello all, my setup of R7000 with CM1000 and EX6400v2. Several times a day, the router losing connection with the modem. The issue does not seem to be an ISP issue as service to modem is in place e...
Jun 11, 2021Guru - Experienced User
What actual firmware is on the R7000?
Its not always "on the latest" or sometimes the latest isn't the best for it.
Do wired connections drop as well?
- gllong21620Jun 12, 2021Tutor
Thanks for your question. R7000 firmware is V1.0.11.106. I do not have any wired connections
- plemansJun 12, 2021Guru - Experienced User
You might try installing the latest 1.0.11.123 firmware. Then do a factory reset and reinstall and see if it helps.
- gllong21620Jun 19, 2021Tutor
Thanks for the suggestion. Seemingly worked for a couple of days, but lost connection between modem and router three times this evening
