gllong21620
Jun 11, 2021Tutor
CM1000 losing connection with R7000
Hello all, my setup of R7000 with CM1000 and EX6400v2. Several times a day, the router losing connection with the modem. The issue does not seem to be an ISP issue as service to modem is in place e...
gllong21620
Jun 12, 2021Tutor
Thanks for your question. R7000 firmware is V1.0.11.106. I do not have any wired connections
Jun 12, 2021Guru - Experienced User
You might try installing the latest 1.0.11.123 firmware. Then do a factory reset and reinstall and see if it helps.
- gllong21620Jun 19, 2021Tutor
Thanks for the suggestion. Seemingly worked for a couple of days, but lost connection between modem and router three times this evening
- plemansJun 20, 2021Guru - Experienced User
You might try installing version 1.0.9.42 version. then do the factory reset and reinstall
- gllong21620Jun 21, 2021Tutor
Thanks so much for the suggestion. Why do you suggest revert to earlier version of firmware? I appreciate the help
