hilton8r's avatar
hilton8r
CM1000 modem / R8000 router - Smart Connect question
I replaced my Motorola modem/router with CM1000 & R8000 after I started having issues with my iphone & ipad showing connected, even though they weren't. I also had problems with unexplained runaway d...
  • DarrenM's avatar
    Jun 18, 2021
    No way to force a device on a band with smart connect enabled it will automatically pick which band which device goes on.
    DarrenM
