net1a
Oct 08, 2021Aspirant
CM1000 no internet
On October 2nd 2021 my interntet stopped working. No device in my home can conect to the internet. I had Comcast come out and they told me the signal is going into the modem but nothing is comming ...
Oct 08, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
net1a wrote:
On October 2nd 2021 my interntet stopped working. No device in my home can conect to the internet. I had Comcast come out and they told me the signal is going into the modem but nothing is comming out. Before he left he said that there was a problem with the last update netgear sent out and that I shoulld contact them. I can not find a way to contact them unless i pay for the support. I am hopping the community might be able to help me.
net1a
Thank you i will try and post there
