Blobblob451
Aug 05, 2022Aspirant
CM1000v2 and R7450 Faster internet Higher ping
Model version: Netgear Nighthawk R7450/ Netgear cm 1000v2 modem. Firmware: R7450 = V1.2.0.92_1.0.1/ CM 1000V2 = V10.01.07 OS: Windows, Android, Linux, IOS, Mac OS. I recently upgraded my internet ...
michaelkenward
Aug 06, 2022Guru - Experienced User
Blobblob451 wrote:
I recently upgraded my internet service from 300mbps down 40 up to 1000mbps down 50 up.
When you changed the Internet service, did you reset the router so that it forgets any settings inherited from your slower service?
In doing so I used to have a ping of 8 (on a wired connection) and it has now jumped to a ping of 24-90 (to my closest server on via Ookla speedtest).
Apart from this measurement, are you having any problems with your connection?
The only other change that I have noticed is the public facing IP address has changed from an Idaho address (the state I am in) to New Mexico.
That is in the hands of your ISP.
Blobblob451
Aug 06, 2022Aspirant
I factory reset both the modem and the router after the service was purchased and confirmed
My connection is very unstable the longest time without dips to 80 mbps or lower that I have had since upgrading is 10 minutes. It causes things like Netflix, Hulu, YouTube to buffer several times in the middle of watching a show as well as loading the same webpages (like the netgear community page) to load instantly or take a minute or longer to load.
Sorry for the confusion I was trying to ask if the public facing IP address moving to a completely different part of the country could contribute to the connection problems.
