Blobblob451
Aug 05, 2022Aspirant
CM1000v2 and R7450 Faster internet Higher ping
Model version: Netgear Nighthawk R7450/ Netgear cm 1000v2 modem. Firmware: R7450 = V1.2.0.92_1.0.1/ CM 1000V2 = V10.01.07 OS: Windows, Android, Linux, IOS, Mac OS. I recently upgraded my internet ...
Aug 06, 2022Guru - Experienced User
I noticed with SpartLight, that sometimes the IP address can come from other regional IP locations, not specific to Idaho. I saw this years ago. SparkLight has regional IPs from other states as well that can be used depending on there allocation policys run and current state of whats already allocated here in Idaho.
Have you run pings from the modem directly with a PC with out the router online?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Please post a copy and paste of the modems connection status page.
