Cpete2528
Nov 25, 2021Tutor
Cm1100 Modem connected to the internet, but wifi says connected without internet
My internet is working when lan connected to my PC. But, when I try to use wifi it says connected without internet. Please help. thank you.
- Nov 26, 2021I went back and tried the nighthawk app again and it worked. Thank you for your time.
Nov 25, 2021Guru - Experienced User
The CM1100 is a modem, not a router.
So its not controlling the wifi.
What router is connected to the modem?
The CM1100 has 2x ethernet ports but the majority of ISP's only allow 1 device to be connected to it at a time. Is anything else connected to the modem? if so, disconnect everything from the modem and power it off for 2 minutes (and your router). Then power the modem back on and give it 2 minutes. Then connect the router back to it and power the router on.
Cpete2528
Nov 25, 2021Tutor
I have the AX4300 router. I have tried unplugging and plugging in several times.
