Cpete2528
Nov 25, 2021Tutor
Cm1100 Modem connected to the internet, but wifi says connected without internet
My internet is working when lan connected to my PC. But, when I try to use wifi it says connected without internet. Please help. thank you.
- Nov 26, 2021I went back and tried the nighthawk app again and it worked. Thank you for your time.
Cpete2528
Nov 25, 2021Tutor
Sorry. RAX45. How do I go about finding the type of firmware or updating?
Nov 25, 2021Guru - Experienced User
You can find manuals, guides, and even the firmware at the support site.
Nighthawk RAX45 | WiFi 6 Router | NETGEAR Support
I'd recommend checking out the manual.
- Cpete2528Nov 26, 2021TutorI went back and tried the nighthawk app again and it worked. Thank you for your time.
