Cpete2528
Nov 25, 2021Tutor
Cm1100 Modem connected to the internet, but wifi says connected without internet
My internet is working when lan connected to my PC. But, when I try to use wifi it says connected without internet. Please help. thank you.
- Jun 18, 2017
The orange color makes since the router you have is 10/100mb wired lan port so the fastest speed t can handle is around a 100mb and flashing of the internet light is normal it would be green if a 1gb lan port was used.
You can find manuals, guides, and even the firmware at the support site.
Nighthawk RAX45 | WiFi 6 Router | NETGEAR Support
I'd recommend checking out the manual.
