timdavis9194
Dec 18, 2020Tutor
CM1150V Connectivity Issues
I installed a Netgear CM1150V modem in April with an Orbi mesh wireless network. Was working beautifully until a couple of weeks ago. Now, I have to do a power off reset at least once a day as it just...
timdavis9194
Dec 19, 2020Tutor
I believe it was the upstream light that wasn’t on the last time.
Dec 19, 2020Guru - Experienced User
do you have screen snips of the cable connections page and the logs? These are key as we look at several things in conjunction.
If you have any splitters, amplifiers, or attenautors, I'd remove them for testing. also check the coax cable for kinks, damage, loose/cheap connectors, or even cheap coax. I've had things like moisture in a line cause issues before. so its always good to try moving the modem to right where the coax enters the home to prevent issues in the home from being the problem.
