edprice218
Nov 19, 2020Initiate
CM1150V modem -Comcast 1Gpbs paired with R8000 X6 Tri band router
Firmwares all at currnet level (CM1150V v04.02.02) (R8000 - V1.0.4.62_10.1.74) CM1150V - Reset to Factory defaults and provisioned CM1150V firmware push from Comcast Xfinity Illinois Xfinity Illi...
- Dec 01, 2020
The R8000 router's speed test in the QoS would never report over 400Mpbs
Had Xfinity/Comcast out they replaced Coax RG6 from pole(arial line) to house to NIB and then RG6 from NIB to splitter with one outlet to TV Box and one to Netgear CM1150V -- then direct connect CAT6 to R8000 wifi router and CAT 6 to PC/MacBook.
I had to reset router to factory defaults - using OoS speed test in Firmware on R8000 still wouldn't report over 400Mpbs
Then using PC wired ethernet to R8000 i was able to obtain 945Mpbs via Ookla and Xfinity speed tests.
Returned the XB7 - good to go.
Speed test inside R8000 is foobar
Nov 20, 2020Guru - Experienced User
When you were testing the cm1150V, did you have the router connected?
Make sure to test it directly off the cm1150v.
So cm1150v-----pc.
what pc are you testing on?
Are you getting full speeds directly off the XB7?
You realize the xb7 has its own integrated router? Do you have the R8000 in access point mode to prevent a double nat?
https://kb.netgear.com/30186/What-is-Double-NAT
- labattNov 20, 2020Mentor
Until recently I used a CM1150V on Comcast 1 gig service. Had no issues with speed, over 900Mbps down and 40 up. So there is no reason why the modem cannot handle what you have. As suggesting try connecting straight to the modem and see what you get,
- edprice218Dec 01, 2020Initiate
- plemansDec 01, 2020Guru - Experienced User
You're right. The built in speedtest is borked.
Reason why is you can't switch what server it connects to for testing speeds and it rarely picks the fastest one.
Its why we usually recommend testing with a pc direct connected to the router.
I'm glad to see that you got the issue fixed though!
If you mark it solved, it might help the next person with your issue.
