ledzep60
May 26, 2021Tutor
cm1200 & R7000 intermittently dropping internet connection but wifi is still on
Hello, maybe someone can help with this issue. I have a CM1200 modem and R7000 wifi router. Over the past 4 weeks we will loose internet connection but the wifi is on. Every device we have is wirele...
May 26, 2021Guru - Experienced User
what actual firmware is on the r7000?
What fixes the issue?
- ledzep60May 26, 2021Tutor
the latest 1.0.11.122
The issue isn't fixed, still happens many times a day. Spectrum has been here 3 times and tested the line right up to the modem and found no issues. But like normal when they are here everything works and the last tech was here it dropped within 10 minutes after he left.
- ledzep60May 29, 2021Tutor
Had Spectrum tech out on Thursday afternoon. He was here over 3 hours and ran a new line from the box on the house to the drop with the modem. Also made a new drop cable from wall to CM1200. Still getting intermittent dropping of internet. It is happenig now only once a day but no indication of the lights on eother the CM1200 / R7000. Anyone have any ideas as to what I can try?
thanks
