ledzep60
May 26, 2021Tutor
cm1200 & R7000 intermittently dropping internet connection but wifi is still on
Hello, maybe someone can help with this issue. I have a CM1200 modem and R7000 wifi router. Over the past 4 weeks we will loose internet connection but the wifi is on. Every device we have is wirele...
ledzep60
May 26, 2021Tutor
the latest 1.0.11.122
ledzep60
May 26, 2021Tutor
The issue isn't fixed, still happens many times a day. Spectrum has been here 3 times and tested the line right up to the modem and found no issues. But like normal when they are here everything works and the last tech was here it dropped within 10 minutes after he left.
- ledzep60May 29, 2021Tutor
Had Spectrum tech out on Thursday afternoon. He was here over 3 hours and ran a new line from the box on the house to the drop with the modem. Also made a new drop cable from wall to CM1200. Still getting intermittent dropping of internet. It is happenig now only once a day but no indication of the lights on eother the CM1200 / R7000. Anyone have any ideas as to what I can try?
thanks
- plemansMay 30, 2021Guru - Experienced User
So you need to determine if its the modem or the router.
directly wire a pc/laptop to the modem and use it for long enough to determine if its the modem or not.
If it stays steady for the peior of time it normally drops, then its a router issue.
Then we work on firmware/router problems.
If it doesn't stay stable, then you'd look at the modem
- ledzep60May 30, 2021Tutor
Setting up a laptop and connecting it to the modem. Will test and see when the issue occurs if the laptop can connect to the internet. I had thought of these but with so much going the plave 2 days I forgot. thanks
