patentlymn
Sep 04, 2021Aspirant
CM1200 connected to AC1750 r6400 no internet. BUT computer direct connect to CM1200 gets internet
I am using a nighthawk AC1750 r6400v2 that was working yesterday when acting as a wirless access port, I think. My son had configured it. I used the wifi to watch youtube etc for months. I just rep...
- Sep 04, 2021
If you'd had it setup in access point mode prior, factory reset the R6400 and then reinstall it in standard router mode.
to factory reset, push and hold reset for 7-15 seconds while its powered on.
install guides for the R6400 can be found here:
R6400 | WiFi Router | NETGEAR Support
also, the CM1200 might have 4x ports but its a modem only device. Only 1 device can be connected to it unless you pay for a business class line or are one of the lucky few that support more (most don't)
patentlymn
I have done a factory reset on both devices.I only have one cable connected to the CM1200, at port 1. It is either from the PC as right now or to the CM1200 WAN when trying to get it to work. Also, I I tried to use port 1 on the r6400 to the PC ethernet port but it connected with no internet. So wired or wireless, no internet through the router.
I looked at the user guide and will look at the links you provided. I really appreciate it.
If it matters, I am using a freshly reinstalled windows 10 on a refurbished dell latitude e6440.
I will do another factory reset on the r6400 and review the manuals.
Thanks
michaelkenward
Sep 05, 2021Guru - Experienced User
Sounds like it might be a good idea to take the R6400 through its setup process.
You connect the modem to the Internet port on the router.
Reset both devices and follow the instructions as specified. The order is important.
- patentlymnSep 05, 2021Aspirant
I gave up on the r6400v2 last night.
I had ordered a used r6400 (not v2) off ebay to use as a wireless access point.
I just tried to set that up as a router using the nighthawk app.
It worked first time. BUT
After connecting the r6400 in the middle of the process the font on my android phone s9+ changed to microscopic and I cannot read it even with a magnifying glass. So I gave up on proceeding with the nighthawk app.I may try again. I may try the routerlogin route but I see there are problems with that.I would like to change the router and wifi passwords.
Oops. I microscopic font just meant I had to click on the entry to bring it up.
I am an idiot.
Plus the routerlogin did not work. It would not come up. A common error I understand.
Thanks to all for the great help.
- michaelkenwardSep 05, 2021Guru - Experienced User
Not really.
routerlogin is far and away the best approach and is far more reliable than using any crippled app.
I would never use an app to set up a device.
But not knowing what you did and where things went wrong, who knows why you hit a brick wall?
Then again, the fact that it didn't work could be important.
