Jazzygal's avatar
Jazzygal
Follower
Dec 16, 2020
CM400 NETWORK SECURITY KEY
Hi,
Setting up a new laptop and it auto-detected Netgear  05 and it is asking for the network security key. No idea! Suggestion??
Thanks
1 Reply
  • > Setting up a new laptop and it auto-detected Netgear  05 [...]
       "NETGEAR05"?
    > [...] and it is asking for the network security key. No idea! [...]
       Look at the product label?
    > [...] Suggestion??
       First: Find your wireless router.
    > Model: CM400|DOCSIS 3.0 Cable Modem
       Is that device new, too?
       The CM400 is a _modem_, not a wireless router.  Follow the Ethernet
    cable from the CM400 to your wireless router.  If it's not connected,
    then you might need to expand your search.
       When you find your wireless router, look on its label for "Model".
    With _its_ model number in hand, you can take the next step:
          https://en.wikipedia.org/wiki/RTFM
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.
       If "NETGEAR05" belongs to your neighbor, and you have only the CM400,
    then you probably want a router.
