BondsteelRS
Nov 10, 2020Tutor
Coaxial a
Hi, Is there available any kind of adapter that could convert the coaxial to an cat5 connection? the place that we are in use only cat5 connection, the internet provider can't help, so the on...
Nov 10, 2020Guru - Experienced User
Your desciption wasn't very clear.
Are you trying to use a coaxial run as a ethernet run? If so, you could look into moca adapters. (ethernet over coax)
BondsteelRS
Nov 10, 2020Tutor
Found them, yes, that was what I meant.
thanks a lot for your help.
