BondsteelRS
Nov 10, 2020Tutor
Coaxial a
Hi, Is there available any kind of adapter that could convert the coaxial to an cat5 connection? the place that we are in use only cat5 connection, the internet provider can't help, so the on...
BondsteelRS
Nov 10, 2020Tutor
Found them, yes, that was what I meant.
thanks a lot for your help.
Nov 10, 2020Guru - Experienced User
Glad that's what you're looking for!
- antinodeNov 10, 2020Guru
> Model: CM400|DOCSIS 3.0 Cable Modem
You have one of those?
> to an cat5 connection?What, exactly, are you trying to do?
> provider can't help, so the only way is to get adapters in any are."the place that we are in"? Do you mean that you are in a building
which provides Ethernet connections for your Internet service? If so,
then a cable modem like a CM400 woud be generally useless to you, withor without any kind of adapters.
"the internet provider"? Care to elaborate?
> Your desciption wasn't very clear._That_ is true.
> Found them, yes, that was what I meant.I doubt it, but from your description of your situation, it's hard to
be sure.MoCA adapters are useful in a situation where you have a co-axial
cable run, but you wish that you had an Ethernet cable run between the
same points. If you do _not_ have a co-axial cable run, and your only
co-axial thing is the CM400, then you don't want MoCA adapters.- BondsteelRSNov 11, 2020Tutor
Hello, to you all,
Let me try to detail this out, and perhaps there will be better resolution,
I work for the AAFES, on a military base, the internet provider that supports all of the base have ethernet connection for the room only, the Netgear routers have coaxial connection only ( three or four models) that we have set on POG, and so we can't sell them as they would need some kind of adapter that will convert the coaxial to ethernet connection thru cat5 cable.
Is that possible? is there aby adapter available.
- antinodeNov 11, 2020Guru
> [...] ethernet connection for the room only, the Netgear routers have
> coaxial connection only ( three or four models) [...]Ok. As I suspected/feared.
> [...] they would need some kind of adapter that will convert the
> coaxial to ethernet connection thru cat5 cable.That sort of adapter would not be practical. MoCA is not what you
want, despite its having the right types of connectors.CMxxxx = cable(-TV) modem, totally useless without a cable(-TV) ISP.
Cxxxx = cable(-TV) modem+router, not useful as a router without a
cable(-TV) ISP, but perhaps not totally useless.It should be possible to configure a model Cxxxx modem+router as a
wireless access point, which might be of some use in your situation. It
depends on what's behind that Ethernet jack in the wall, but running the
experiment could be educational. For the details, see, for example:
https://community.netgear.com/t5/x/x/m-p/1463500That's written for a Netgear C6300-as-WAP, but the steps are about the
same for any other router (any make/model) which lacks a one-step WAP
option. (Especially similar for another Netgear Cxxxx.)If the equipment behind the Ethernet jack in the wall permits, a WAP
could provide wireless access, and perhaps another couple of Ethernet
ports (depending on how many there are on the particular Cxxxx). It
would not provide any privacy/isolation of the kind which a NAT router
would. Whether anyone cares, I couldn't say. In that respect, it
should be no worse than connecting a computer/device directly to the
Ethernet jack in the wall.
Thanks a lot, I guess we will have to return them all back to DC or vendor, or transfer them to another location.
have a great day and thank you all for the time and help.
stay safe.
> [...] I guess we will have to return them all back to DC or vendor, or
> transfer them to another location.Yeah, it's likely that they'd be more useful to someone else as real
cable modems/modem+routers. At least you dodged the MoCA adapters.> have a great day [...]
And a suitably solemn Armistice Day to you, too.
> stay safe.That sounds like your job, but I'll try to do my part.
