ChuckC3
Oct 30, 2021Aspirant
Comcast Compatibility - CAX30
I have a new CAX30 Cable Modem/Router that I have had for less than a month that I purchased to replace an equivalent Comcast product that I was renting. Everything in my network works fine except I...
Oct 30, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
The CAX modem is compatible with CC.
Thank you.
