GCKERN
May 03, 2024Aspirant
COMCAST EMAIL
Recently, my Comcast email stopped working to my OUTLOOK and iPhone (iPad too) only while on my home network (serviced by my 4 year old #R7000P). All other email accounts (Google, Yahoo, iCloud, Cha...
michaelkenward
May 03, 2024Guru - Experienced User
GCKERN wrote:
Recently, my Comcast email stopped working to my OUTLOOK and iPhone (iPad too) only while on my home network (serviced by my 4 year old ##R7000P).
ISPs have a habit of changing the settings for their email services. I'd start there. It probably has noting to do with the R7000P. The router doesn't care about the email services you use. More likely to be the Outlook configuration.
Your AC2300 WiFi Router (R7000P) may be four years old, but this model is from 2017. You could check that Comcast hasn't done something to its email security settings.
- GCKERNMay 04, 2024Aspirant
Again, the email connection via Outlook works fine connected directly to my cable modem, it's only when I put the Nighthawk in line that I have issues. Also note that all other email services seem to work fine either way. I have spent a few hours chatting and talking with Comcast and they are befuddled. Same with my iPhone, works out side the house off my network fine. I agree it makes no sense, but the Nighthawk seems to be the variable that is causing the issue(s).
- KitsapMay 04, 2024Master
Have you enabled IPv6 in the configuration of your R7000P?
Are you using Comcast DNS, either IPv4 or IPv6, or some public DNS?
- GCKERNMay 05, 2024Aspirant
I Have always used the default ISP DNS (Charter/Spectrum) but I had tried changing primary DNS to Google (8.8.8.8) and no change in behavior. Have not adjusted any settings to IPV6.
- FURRYe38May 05, 2024Guru - Experienced User
E31N2V1 ISP is Spectrum (Charter). Email is legacy from Xfinity (Comcast). Email via outlook works fine direct connected to that.
