GCKERN
May 03, 2024Aspirant
COMCAST EMAIL
Recently, my Comcast email stopped working to my OUTLOOK and iPhone (iPad too) only while on my home network (serviced by my 4 year old #R7000P). All other email accounts (Google, Yahoo, iCloud, Cha...
Kitsap
May 04, 2024Master
Have you enabled IPv6 in the configuration of your R7000P?
Are you using Comcast DNS, either IPv4 or IPv6, or some public DNS?
GCKERN
May 05, 2024Aspirant
I Have always used the default ISP DNS (Charter/Spectrum) but I had tried changing primary DNS to Google (8.8.8.8) and no change in behavior. Have not adjusted any settings to IPV6.
- KitsapMay 05, 2024Master
GCKERN wrote:I Have always used the default ISP DNS (Charter/Spectrum) but I had tried changing primary DNS to Google (8.8.8.8) and no change in behavior. Have not adjusted any settings to IPV6.
Are you working with the Outlook client application from Microsoft 365 or the one from the application store?
For a test, I would recommend you enable IPv6 on your router. There are a couple of options for the connection, one is auto the other is DHCP. Try both. Access to the Comcast e-mail servers may need IPv6.
Comcast had a data breach several months ago and then forced e-mail users, including legacy, to reset their passwords. Have you been forced to reset your password?
- GCKERNMay 09, 2024Aspirant
Had a similar problem (although only id'd with iOS devices at the time) close to the time we needed to change our passwords (January timeframe I believe) - but that cleared itself. I have replaced the Nighthawk with a Linksys (and made NOT IPv6 changes etc., setup with defaults) and everything now works fine.
