popowell1-
Nov 06, 2020Aspirant
Comcast WiFi extender. Will they work with Netgear router
Comcast WiFi extender. Will they work with Netgear router. I have consist as my provider. Recently replaced a Comcast router with a netgear and I can’t see if the extenders are worth.
antinode
Nov 06, 2020Guru
> Comcast WiFi extender. [...]
How much do you expect anyone here to know about your (unspecified)
"Comcast WiFi extender"? Has it a maker and model number? Did Comcast
provide any information on its capabilities, or instructions for its
use?
> [...] Will they work with Netgear router. [...]
Ask Comcast? Have you tried anything? What happened? Why wouldn't
they?
> [...] Recently replaced a Comcast router [...]
Not a very detailed description of that device, either. Did your
(unspecified) "Comcast WiFi extender" work with your (unspecified) "a
Comcast router"?
- popowell1-Nov 06, 2020AspirantI didn’t ask for a SmartAss answer either. Yes, No or how about not reply dip**bleep**.
- antinodeNov 06, 2020Guru
> I didn't ask for a SmartAss answer either. [...]
As we said when _I_ was a child: Better a smart answer than dumb
question.> [...] Yes, No [...]
Based on what information, exactly, would you like that answer to be
based? Your absent replies to requests for even the most basic
information? Good luck with that.- popowell1-Nov 06, 2020Aspirant
Didn’t know I connected with Geek squad. Simple question for users. Netgear c7000 router How about this childish response.
