Retired_Member
Sep 04, 2021COME ON NETGEAR WAKE UP AND FIX THE BROKEN DNS YOU CAUSED
WAKE UP NETGEAR. FIX THE DNS ISSUE YOU CAUSED WITH THE FLAWED FIRMWARE UPDATE. PLEASE REALISE WE BUY ROUTERS TO USE THE INTERNET, SO IF THEY DONT WORK ALTERNATIVE VENDORS WILL BE FOUND.
Retired_Member
Sep 04, 2021Yes I fully understand that this is not an official Netgear forum. But how else can one get Netgear do fix their products so they work as they are supposed to. Netgear so called support is non-existent, having tried to get a response from someone there.
Sep 04, 2021Guru - Experienced User
Did you try downgrading the firmware? Theres been more than 1 model effected by the dns issue on the curent firmware.
- Retired_MemberSep 04, 2021
I have not downgraded yet. I 'fixed' the with a temorary work around so I would have the up to date security fixes. D
- michaelkenwardSep 05, 2021Guru - Experienced User
Retired_Member wrote:
I 'fixed' the with a temorary work around ...
What was that? I'm sure that people would love to know.
- Retired_MemberSep 05, 2021
This is the workaround I used:
Go to into routeradmin pages go to advanced home and note the dns entries.
Go to windows control panel and click on ‘Network and sharing centre’
Click ‘change adaptor settings’. DoubleClick the ethernet/wifi adaptor and click properties,
highlight Internet protocol version 4(TCP/IPv4) click properties:
Click ‘use the following DNS server address’ and enter dns numbers in the ‘preferred dns server’ and alternative server boxes.
See previous threads
