ejbpesca's avatar
ejbpesca
Compatibility of Android Genie
My code on the bottom of my wifi/modem will not be accepted by the latest version of the Android Genie app I understand will no longer load to my laptop and is not available.  The old Genie worked fi...
  • ejbpesca's avatar
    ejbpesca
    Mar 11, 2021
    List said a
    • SanDisk Ultra 16GB USB3.0  is compatible.  My C drive has 130 GB of data.  I guess the Ready Share mirrors this C drive by backing up every update, new file, app, etc. so I would go for a SanDisk at least 256GB yet such a small 16GB is said compatible.  Maybe that is for a setting in the backup system to backup say one folder, not the whole system.  I am going to guess that Sandisk products are okay to use at sizes at least up to 1 TB.
