wad
Feb 05, 2022Aspirant
Compatibilty with WD live media box
I use a Western Digital Live 3 gen. media box to steams from my server. It has worked well without issue in the past. Recently however the WD is unable to connect with my network wired or wirelessly....
- Feb 13, 2022
Thank you for the help.
I set the box to an IP address I had reserved and also set the gate way and mast addresses.
This seems to have resolved the problem.
I'm still curious to know why this problem asserted itself after these years of problem free use.
It occurred on both the box I had used and the spare I had, were both had work before without any adjustments.
If you happen to think of anything let me know, this like an itch I need to scratch.
Thanks again for your help.
wad
Feb 06, 2022Aspirant
Since have been using the WD box since 2016 without a problem. The problem occurred this last week. As I traded out the WD box with a spare I had and the problem still occurred it eliminated any problem with the WD box. I also reviewed the setting and reset both boxes. After several attempts to trouble shoot the router I temporally solved the problem then it reoccurred after trying to reconnect to router.
I really don’t want to rest the router to factory setting.
Feb 06, 2022Guru - Experienced User
A reset maybe needed to check this.
- wadFeb 06, 2022Aspirant
I completed a reset and still having the same problem.
- FURRYe38Feb 06, 2022Guru - Experienced User
What is the exact model# of these WD devices?
When I turn off the router I get to the WD menu and set it to detect source for WiFi. I then turn on the router select my router and then can get a connection. I took the opportunity to set a static IP for the WD box. The WD would not reconnect after being powered down.
Is this it? https://www.amazon.com/Media-Player-Wi-fi-1080p-Version/dp/B005KOZNBW
