JG627
Jul 21, 2020Follower
Compatible APs for Nighthawk R6700
I have a nighthawk r6700v3 router and am unable to have adequate coverage throughout my house. I tried purchasing extenders but that didn’t work. I have an ability to have a wired data link between tw...
- Jul 21, 2020
I would skip messing around and get a mesh system like orbi. It allows you to use wired or wireless backhauls and you can add satellites as needed. plus it uses the same ssid for the network. It'd be a bit more of a buy in buy they've been fairly cheap on amazon renewed lately with the release of the orbi AX devices.
Jul 21, 2020Guru - Experienced User
