Helles's avatar
Helles
Initiate
Sep 16, 2021
Compatible WiFi Dongle for Windows 2016 Server
Need a USB 3 WiFi dongle that will work with Windows 2016 Server Standard.
  • plemans's avatar
    Sep 16, 2021
    If it works with windows 10 it should work with server 2016.
    I've tried a couple different ones (not netgear) with my windows server 2016 and not had issues.
    I've just done it for testing as I prefer my servers hardwired in. Or with a bit wider of backhaul.
    You could also get a (decent) wireless extender and hardwire it in. Then you have the added benefit of a wireless extender to add coverage/capabilities.
