hands4
Sep 11, 2021Aspirant
Compatible XR500 Mesh Extension
Which routers work as mesh extenders for the XR500?
- Sep 11, 2021
routers and extenders are 2 different things.
Pretty much all of netgears extenders will connect to the XR500.
You just have to choose the features/performance that you want. Like the mesh option.
Or triband.
https://www.netgear.com/home/wifi/range-extenders/
Sep 11, 2021Guru - Experienced User
Be sure to visit and post over in the Nighthawk Gaming router forum:
Good Luck.
