hands4's avatar
hands4
Compatible XR500 Mesh Extension
Which routers work as mesh extenders for the XR500?
  • plemans's avatar
    Sep 11, 2021
    routers and extenders are 2 different things.
    Pretty much all of netgears extenders will connect to the XR500.
    You just have to choose the features/performance that you want. Like the mesh option.
    Or triband.
    https://www.netgear.com/home/wifi/range-extenders/
