jtcon40
Sep 16, 2021Follower
Completely Useless Equipment And Service
DO NOT PURCHASE NETGEAR PRODUCTS! Warning - faulty products and no competent technical support! I purchased nearly $600 worth of "TOP OF THE LINE" Netgear products and my in home WiFi has NEVER BE...
timberwolfny
Sep 16, 2021Guide
I completely agree. I have the orbi system rbr850 and it is a buggy mess that has constant disconnect. Worse system i have ever bought. Why did i sucumb to online reviews. Never has this kind of problem on asus routers throught 3 different upgrades. If you value your money do not buy netgear router.
Sep 16, 2021Guru - Experienced User
My CM2000 and Orbi 8 series are working well for me.
I recommend posting in the right forums for the Orbi AX, RAX and CM product lines if you want visibility. This forum is specific to the Nighthawk R 6, 7, 8 and 9 series router product lines.
Good Luck.
