chasm31110
Sep 15, 2021Aspirant
config file
Is it possible to use the config file on different model routers of the same brand?
- Sep 15, 2021
I wouldn't do it/try it (if it'd even let you).
They use different hardware.
Even some of the same models with different versions use different hardware.
Sep 15, 2021Guru - Experienced User
- chasm31110Sep 16, 2021Aspirant
thanks
