chasm31110
Sep 15, 2021Aspirant
config file
Is it possible to use the config file on different model routers of the same brand?
- Sep 15, 2021
I wouldn't do it/try it (if it'd even let you).
They use different hardware.
Even some of the same models with different versions use different hardware.
michaelkenward
Sep 16, 2021Guru - Experienced User
To add to the response from plemans, this is a long-running issue, with its own venerable discussion in the suggestions zone. There's never much in the way of a response from Netgear.
Never rebuild a configuration from scratch again! - NETGEAR Communities
It seems to be an industry wide problem. You can't export and reimport bits of the configuration.
My solution is to file away a set of screenshots of key settings.
