msurls
May 25, 2023Aspirant
Configuration Error when updating WiFi credentials/settings
 App Version: 2.26.0.61  Firmware Version: V1.2.0.92_1.0.1  Model Number: R6900v2     I am getting a Configuration Error when updating WiFi credentials/settings.     I've tried rebooting the router, c...
- May 25, 2023They make USB to ethernet adapters that are cheap. Connect the laptop to the SSID and PW of the router, then Log into the routers web page using Safari or Firefox browser at 192.168.1.1.
May 25, 2023Guru - Experienced User
Use a wired PC and web browser to make the changes to the wifi settings on the router.
msurls
Thanks for responding!
I don't have any wires that would connect my mac to the router.
And where would I go in my browser to update the WiFi settings?
- FURRYe38May 25, 2023Guru - Experienced UserThey make USB to ethernet adapters that are cheap. Connect the laptop to the SSID and PW of the router, then Log into the routers web page using Safari or Firefox browser at 192.168.1.1. - msurlsMay 25, 2023AspirantThanks. I was able login and update the setting in my browser without being wired. - FURRYe38May 25, 2023Guru - Experienced UserGlad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
 Enjoy. 📡
