Lupatin
May 07, 2017Aspirant
Configuration Issue
After a reboot my Router does not start with the saved configuration but with the default one. I've try to modify it but the results is the same. My firmware version is 1.0.1.16.
- May 15, 2017
The default IP address of the Telecom Router is 192.168.1.1. I've changed this and now also after the reboot both devices works fine. Thanks for your help.
Lupatin
I use the router with the Wan option enabled because I use the router of the fiber optic provider. After the reboot I lose the configuration stored and I see only the wizard for a new installation.
May 07, 2017Guru - Experienced User
What is the Mfr and model of the Fiber ONT? If the ONT has a built in router, then this behavior of the NG router is indicitive of it detecting a router ahead of it up stream. If the ONT has a built in router already, you might try have it bridged if possible or use it's DMZ for the NG router. Might also check the ONTs IP address string. It should differ from 192.168.1.1, if its the same, you can change the NG routers IP address to 192.168.0.1.
You can run the NG router as a wired LAN AP mode as well if your going to use the ONT as the main host router.
