Lupatin
May 07, 2017Aspirant
Configuration Issue
After a reboot my Router does not start with the saved configuration but with the default one. I've try to modify it but the results is the same. My firmware version is 1.0.1.16.
- May 15, 2017
The default IP address of the Telecom Router is 192.168.1.1. I've changed this and now also after the reboot both devices works fine. Thanks for your help.
Lupatin
I've try with Opera, Firefox and IE and also with different HW (Mac and Pc). After the reboot the connection is very slow too.
- FURRYe38May 07, 2017Guru - Experienced User
Be sure QoS is disabled on the router.
If your going to use the ONT as the main router, change the NG router to AP mode and connect it LAN to LAN. Don't use the WAN port.
