Lupatin
May 07, 2017Aspirant
Configuration Issue
After a reboot my Router does not start with the saved configuration but with the default one. I've try to modify it but the results is the same. My firmware version is 1.0.1.16.
- May 15, 2017
The default IP address of the Telecom Router is 192.168.1.1. I've changed this and now also after the reboot both devices works fine. Thanks for your help.
Lupatin
I will try with this. Thanks
