PatienceIsNeede
Jan 09, 2022Aspirant
Configure LAN as Wan Port Netgear Nighthawk RAX70
Is there anyway at all to change to a LAN port to WAN port on the Nighthawk RAX70? My WAN port is dead and ive tried everything to check its not just a software issue. I have reseted the router multi...
Jan 09, 2022Guru - Experienced User
Swap LAN cables between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
You might contact NG support and ask about an RMA for your router:
https://my.netgear.com/support/contact.aspx
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
microchip8
Jan 09, 2022Master
I don't know if the RAX models have it too, but on my R7800 at http://192.168.1.1/debug.htm there's an option to WAN Port mirror to LAN port1
- michaelkenwardJan 10, 2022Guru - Experienced User
PatienceIsNeede is more likely to get an answerr ti that in the righy section for the RAX.
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
In the meantime they could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads. - PatienceIsNeedeJan 10, 2022AspirantI checked just incase ,but there's no option to mirror the WAN onto a LAN.
Thank you.
