PatienceIsNeede
Jan 09, 2022Aspirant
Configure LAN as Wan Port Netgear Nighthawk RAX70
Is there anyway at all to change to a LAN port to WAN port on the Nighthawk RAX70? My WAN port is dead and ive tried everything to check its not just a software issue. I have reseted the router multi...
microchip8
Jan 09, 2022Master
I don't know if the RAX models have it too, but on my R7800 at http://192.168.1.1/debug.htm there's an option to WAN Port mirror to LAN port1
michaelkenward
Jan 10, 2022Guru - Experienced User
PatienceIsNeede is more likely to get an answerr ti that in the righy section for the RAX.
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
In the meantime they could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
