PatienceIsNeede
Jan 09, 2022Aspirant
Configure LAN as Wan Port Netgear Nighthawk RAX70
Is there anyway at all to change to a LAN port to WAN port on the Nighthawk RAX70? My WAN port is dead and ive tried everything to check its not just a software issue. I have reseted the router multi...
PatienceIsNeede
Jan 10, 2022Aspirant
I have tried restarting my network in that order and no luck. The router was working just fine for a couple of months until this issue appeared.
When the issue first started I was on firmware 1.0.3.92 but I've recently updated to 1.0.11.112 to see if it would help at all, but the problem persists.
I did contact Netgear support and have an open support case but it's been over a month and no response from them.
I'll go make a post in that specific community and see if I have any luck with there.
Thank you.
Thank you.
Jan 10, 2022Guru - Experienced User
Be sure you maintain contact with NG support. Keep poking them.
Thank you.
