x6bandoleer's avatar
x6bandoleer
configure private wifi with NO broadband
i have a wavelan outdoor router in AP configuration that provides 2.4 to wifi ip cameras (AP/cam branch).  this is connected to a netgear r7000 that is a gateway for the entire system.  the r7000 doe...
  • x6bandoleer's avatar
    Sep 09, 2023
    to (maybe) answer this myself:
    although i am unable to verify it works, by selecting TCP & the maximum port range in the security/service block feature, this effectively blocks the Ethernet port.
