greg-07
Jan 29, 2021Follower
configure Smart Wifi Router with Comcast Cable Modem/router
Cable Modem/Wifi Router is connect to the Nighthawk, but I can't tell if my wireless connection is routing directly to the ARRIS modem/router or the Nighthawk. How can I ensure that the wifi signal ...
DarrenM
Jan 29, 2021Sr. NETGEAR Moderator
You will need to login into the Arris modem and disable the wifi or set it to modem only mode.
DarrenM
