jakeagle
Oct 26, 2020Tutor
Configure two Nighthawks behind a Ubiquity edge router
Hi, I will be installing 2 Nighthawk R7800 behind a Ubiquity Edgerouter X. The first Nighthawk will provide wireless SSIDs and should have DHCP disabled (Bridge Mode or just disable DHCP). The...
- Oct 26, 2020
One some of my routers, in ap mode, you leave it plugged into the wan port. On others, you have to move it to the lan port. you can check your specific devices settings and it'll show you. I believe for the R7800 you can leave it in the wan port.
https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode
jakeagle
Oct 26, 2020Tutor
Thank you for the fast reply.
To make sure I have this right. Plug into a LAN port on each Nighthawk and nothing in the wan port? Will AP mode let me set the SSID and pass phrase? Just use the same settings on each Nighthawk?
Oct 26, 2020Guru - Experienced User
- jakeagleOct 26, 2020Tutor
Thank you. You've be a huge help and it is greatly appreciated. Have a good day.
