_JR
Nov 03, 2021Aspirant
Configuring Modem Nighthawk X4S AC2600 Smart WiFi Router Model RC8700
I need to reconfigure the router. I reset the router. (using the reset switch & paperclip) I can login with name and password. Followed by serial number. Now I'm being asked (Router Password Reco...
- Nov 11, 2021
I was able to figure out how to get to the config settings and am now a happy camper.
Thanks everyone!!
_JR
Nov 11, 2021Aspirant
Thanks everyone!!
Nov 11, 2021Guru - Experienced User
Good to hear.
Please mark your thread as solved so others will know.
Enjoy.
