hardikpatel172
Dec 28, 2015Aspirant
Configuring Switch and Wi-fi Router in same network
Hi Team, I have below setup presently as shown in below image. To describe the same internet cable is connected to a Cisco switch, which is connected to PCs in LAN (Wired). One output from Switch...
- Dec 29, 2015
I did hard reset wi-fi router and configured it in Access Point mode which solved my problem.
netwrks
Dec 28, 2015Master
It should go as follows: ISP modem<------>wifi router<----->switch<-----> wired devices, all in the same subnet. DHCP enabled at one point only, in your network.
Ideally your switch and device can support gig, (1000Mbps). Ensure at least CAT5e Ethernet is used between all your wired connection points.
Is the ISP device a modem only or a router / modem combo? If it is the latter, is the device bridged?
- hardikpatel172Dec 28, 2015Aspirant
Thanks for your reply. I have already tried the way you have shown as mentioned in my problem statement and it works fine. My doubt is whether can we make some settings with the attached image's architecture and have all devices in a network ?
My Wifi Router is Nighthawk AC 1900 Smart WiFi Router -Model # R6900.
