Computertech50
Jun 22, 2016Aspirant
Connect a remote network to Nighthawk R7000 via VPN
I need to connect a remote network to a Nighthawk R7000 router. The remote network is for IP cameras so that the camera server behind the R7000 can pick up their feeds. With it being cameras I don't ...
- Jun 24, 2016
I use Asuswrt-Merlin and I can confirm that OpenVPN client support is built in. There are many different builds of DD-WRT, only some of which will include OpenVPN client support. I believe Tomato has it built-in, but you should seek independent confirmation.
storm1985
Jun 23, 2016Prodigy
I suggest on your remote PC install the OpenVPN client software to connect to the R7000 OpenVPN server. Once connected, you can access your cameras as if you are on the same local network as the R7000.
Computertech50
Jun 23, 2016Aspirant
As I said above, what I am trying to connect to the primary network is IP cameras. There is no place to install client software. Its not a PC, its IP cameras. Installing software on them is not an option. I need a network hardware box in front of it to connect the remote net to the primary net connecting to the Nighthawk R7000.
- storm1985Jun 23, 2016Prodigy
please read again my comment and understand what I am trying to suggest. With what I suggest you dont have to purchase a new hardware on your other network. You just need the OpenVPN to work with your client devices.
for ur point of getting another hardware it is not an option if you will be using the NETGEAR stock firmware. Not with OpenVPN you need IPSec or L2TP VPN. Try ddwrt firmware.
- Computertech50Jun 23, 2016Aspirant
Im not understanding your suggestion then. The camera server, which records the camera feeds and is a dedicated proprietary piece of hardware, is on the primary network along with the majority of the cameras. The cameras at the remote location have to be seen across the network by the camera server via IP. I have to have a direct connection from one net to the other. There isn't a PC even at the remote loaction. What I'm hearing is you can't connect to the OpenVPN server on the R7000 with any standard hardware?
- TheEtherJun 23, 2016Guru
You can get a second R7000, install DD-WRT, Tomato or Asuswrt-Merlin, and use the built-in OpenVPN client to connect back to your main network.
