njcwotx
Jan 20, 2021Aspirant
Connect a wired device to wifi in another room
I have a 6230 and a 6020. 6230 is connected to Cable modem. It works perfectly as a wifi router. All wireless devices connect to internet, and wired devices connect to internet. I have a phy...
- Jan 21, 2021
> I have a 6230 and a 6020. [...]
R6230? R6020?
> [...] Cable modem [...]
Maker? Model number?
> I have a physical server [...]
Not a very detailed description of that device, either.
> I thought this was called bridge mode. [...]
I agree.
> I setup bridge mode on the 6020, [...]
How, exactly?
> [...] but it doesnt every ask me for the wifi router information.As I read the R6020 User Manual, it lacks the desired feature. Same
for the R6230, for that matter. The word "bridge" does appear, but not
in the right context.> Do I have the concept wrong here?
The concept is ok, but your routers apparently lack the relevant
feature. If you consult the User Manual for a different/better model,
like, say, the R7000, and look for "Set Up the Router in Bridge Mode",
then you should see how to do what you want (with a router which does
have the desired feature).Visit http://netgear.com/support , put in the model number of
interest, and look for Documentation. Get the User Manual. Read.Very likely there are wireless-network adapters which could be
installed in or attached to your (unspecified) "a physical server" which
would give it wireless-network capability. Or, if you had a router in
your junk box which had the desired feature, then you could use it.Other options exist, too, but would tend to cost more (Powerline
adapters, for example).
antinode
Jan 21, 2021Guru
R6230? R6020?
I agree.
How, exactly?
njcwotx
Jan 21, 2021Aspirant
R6230? R6020? = yup, i had clicked the router type box at the top and it does appear in the post.
Maker? Model number? = not necessary in this scenario, the wifi router connected passes traffic correctly, as noted.
Not a very detailed description of that device, either. = its a dell tower box without a wifi card. it runs ESXi 7 (server is on the hcl) which isnt known to have nic drivers for all sorts of off the shelf wifi cards. I didnt feel that needed explaining to get the gist of the question across.
How, exactly? = I went to advanced, vlan/bridge setup. Like it said in the manual on page 83 for the R6020.
in the right context. === so that explains it...the "bridge setup" mentioned in manual is not the type of bridge I wanted. Time to shop for another model. This time ill be sure to check it for 'bridge mode' features.
thanks for answering.
