njcwotx
Jan 20, 2021Aspirant
Connect a wired device to wifi in another room
I have a 6230 and a 6020. 6230 is connected to Cable modem. It works perfectly as a wifi router. All wireless devices connect to internet, and wired devices connect to internet. I have a phy...
- Jan 21, 2021
> I have a 6230 and a 6020. [...]
R6230? R6020?
> [...] Cable modem [...]
Maker? Model number?
> I have a physical server [...]
Not a very detailed description of that device, either.
> I thought this was called bridge mode. [...]
I agree.
> I setup bridge mode on the 6020, [...]
How, exactly?
> [...] but it doesnt every ask me for the wifi router information.As I read the R6020 User Manual, it lacks the desired feature. Same
for the R6230, for that matter. The word "bridge" does appear, but not
in the right context.> Do I have the concept wrong here?
The concept is ok, but your routers apparently lack the relevant
feature. If you consult the User Manual for a different/better model,
like, say, the R7000, and look for "Set Up the Router in Bridge Mode",
then you should see how to do what you want (with a router which does
have the desired feature).Visit http://netgear.com/support , put in the model number of
interest, and look for Documentation. Get the User Manual. Read.Very likely there are wireless-network adapters which could be
installed in or attached to your (unspecified) "a physical server" which
would give it wireless-network capability. Or, if you had a router in
your junk box which had the desired feature, then you could use it.Other options exist, too, but would tend to cost more (Powerline
adapters, for example).
Mudpupp
Jan 27, 2021Aspirant
May I suggest a WiFi extender. Most dual band extenders plug into the wall an connect via WiFi to your main router. These also have a physical port for connecting “wired only” devices.
njcwotx
I tried a R6700v3, it setup fine, but quickly dropped packets and connections when under data transfer. However, I had an old linksys e1200, loaded dd-wrt and setup the bridge, it worked perfect. It even allowed me to repurpose the WAN port to a LAN port, now i have 5 ports usable.
Interestingly enough.. the manual for R6700 has bridge mode setup, but the manual for R6700v3 does not. However, I did find a radio button in advanced wireless setup called "other mode" when checked offered the option for bridge mode.
