MarcRobeets
Dec 25, 2020Aspirant
connect access point WNDR4300
I have a modem in the basement from my provider and an WNDR4300 access point in the living room for a better connection also from my provider. Both have the same SSID and password and the same confg...
schumaku
Dec 25, 2020Guru - Experienced User
MarcRobeets wrote:Both have the same SSID and password and the same confguration.
Everything worked well, bu ti have a new phoen now: Xiaomi Poco X3 working with Android.
Was this WiFi connection migrated from a previous Android phone? Appears this device has issues with these. Remove the connection on the phone any re-add it by discovery and manually enrering the password/PSK..
