MarcRobeets
Dec 25, 2020Aspirant
connect access point WNDR4300
I have a modem in the basement from my provider and an WNDR4300 access point in the living room for a better connection also from my provider. Both have the same SSID and password and the same confg...
michaelkenward
Dec 26, 2020Guru - Experienced User
What is the modem? (It sounds like a modem/router if it does wifi.)
Is the WNDR4300 configured in AP mode? Is it wired to the modem? (The WNDR4300 can also do "WDS" and work as a wifi repeater.)
MarcRobeets wrote:
It does connect with the acces point, only with the modem in the basement
Is there a "not" missing in there? As in "It does not connect" to the access point?
