LMTracey
Dec 26, 2020Aspirant
Connect another either net cable to cellspot device
- LMTraceyAspirantShould clarify I just changed mobile serves and needed to get better service in my home T-Mobile sent me a personal Hotspot device -4LTG Cellspot. I’m supposed to connect their rithernet cable to my Nighthawk R7000 router but the only rithernet connect in the router is connect to my Sorctrum Modem. So need suggestions as to connect hotspot to router. Thanks
- No1MportntLuminary
You will only be able to connect one cable to the router for internet service.
Not real sure exactly what you are trying to accomplish so if you could be a little more specific with exactly what you are needing maybe it will help determine what needs to be done.
- LMTraceyAspirantInstructions say to connect the yellow ethernet cable from low WAN yellow port on your 4G LTE cell spot to an available ethernet port on your Wi-Fi router a Wi-Fi cable modem router and then position the antenna as best as possible don’t know how I’m supposed to do that if there’s only one ethernet input on my router. Unless I can use my modem port?
