tbeernot
Aug 24, 2021Aspirant
Connect R8000 to internet via Wifi
I have a Wifi AC and N netwerk in my house and need to connect a number of devices that do not have WiFi capability themselves. So I am wondering if it is possible to configure a R8000 to connect to ...
microchip8
Aug 24, 2021Master
No
- tbeernotAug 24, 2021Aspirant
You don't need to be that clear. Leave me some hope. :-)
Thanks for the answer.
NB: I have figured out that the technical name for this setup is a wifi bridge or wireless bridge.
- michaelkenwardAug 25, 2021Guru - Experienced User
The R8000 does not support wifi repeater (or wireless bridge) mode.
You can use the R8000 as a wireless access point, with a LAN connection to your router.
If you can't run a LAN cable far enough, then Powerline Ethernet can use your mains circuit to fill the gap.
